PCM Code - Ford Powerstroke Diesel Forum
Old 09-09-2009, 09:36 AM
PCM Code
This Sounds like a Retarded question, but Wheres the PCM and wheres its code? I thought it was under the hood on the drivers side wall, but people say you install the chip under the parking brake pedal, so where is it?
and where can i find the Code, so i can order my TW chip??
Old 09-09-2009, 12:31 PM
its also on the door the cabration number
Old 09-09-2009, 03:13 PM
Just loosen the 3 nuts that hold e brake assembly in place. The pcm is right behind there. Pop the hood and look for a 10mm bolt holding it in place. Btw the nuts on e brake are 1/2 inch. Good luck bud
Old 09-09-2009, 03:28 PM
a truck
you dont need to give it to them, I have never gave any custom tuner my PCM code, they are able to figure it out based on the year of your truck and everything
Old 09-09-2009, 06:19 PM
ok thanks guys
