Speedometer going crazy - Ford Powerstroke Diesel Forum
Old 09-08-2009, 05:20 PM
My speedometer is intermittently fluttering from peg to peg full sweep really fast and is throwing the ABS light. I have read other threads on the forum about speedo issues, but they all seem to deal with speedo's that just bounce about 5 mph or so. Mine is really bad and makes a clicking sound as the needle bounces off of the pegs (it is really annoying). I took the sensor out of the rear end and cleaned it, but it didn't solve the problem. Should I just order a new sensor, or could it be the speedometer itself? Any thoughts are greatly appreciated!
Old 09-08-2009, 06:22 PM
I have seen that with the axle sensor.
Old 09-08-2009, 07:13 PM
Powerstroke Techie
Yep sounds like the rear wheel speed sensor. At least that's where i would start.
Old 09-08-2009, 07:44 PM
Ok, thanks for the help! I'll try to pick one up tomorrow and see if it fixes it.
Old 09-09-2009, 08:44 PM
I picked up an new sensor today and problem solved. Thanks again for the help!
Old 02-25-2010, 06:40 PM
Question speedo, odometer problems
when i ride on rough roads my speedo bounces and my odometer will either go blank or read partial numbers i dont know it may be the vss also my abs light has been on since i bought the truck and my od light will flash, the od light flashing doesnt happen that often its done it maybe 5 times in the past six months but the speedo, odometer, and the abs light is a constant problem, would the vss cause all these problems
