1997 F250 PS solid axle swap from 99 F250 Possible?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-13-2009, 09:37 PM Thread Starter
Smile 1997 F250 PS solid axle swap from 99 F250 Possible??
HI,
New to this wonderful forum here. I currently have a 97 F250CC PS. It's got the wimppy ttbD50. I currently just took hold of a set of axles from a rolled 99 F250. My question is, Can the axles from the 99F250 both front and rear be swapped into my 97 F250? I did some measurements and seems as though the mounting points for the leafs springs are the same. Any info, or help is great appreciated thanks.
LoGan
LoDhaseng is offline
post #2 of 11 Old 08-14-2009, 09:35 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Yes you can you will need some custom parts but if I can put '08 axles in my '97 those will be easy!
CT Performance, Inc. is offline
post #3 of 11 Old 08-14-2009, 11:21 AM
FordGuy100's Avatar
Some modification like said. And remember the bolt pattern is different, its 8-170mm
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #4 of 11 Old 08-14-2009, 11:38 AM
Tennessee Powerstrokes
GoFastPadre's Avatar
Originally Posted by LoDhaseng View Post
HI,
LoGan
Welcome to the Addiction um I mean Org! You can do anything you set your mind to my friend. The word can't is not allowed! Have fun and be safe!
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
post #5 of 11 Old 08-18-2009, 08:58 PM
KeepinItFord's Avatar
Im Doing 01 Axles right now! its great because of the 4 wheel discs
KeepinItFord is offline
post #6 of 11 Old 08-19-2009, 01:42 PM
a straight axle from an 01 dually would not bolt right up to my 95, you wouldve had to move the shock perches, and custom make the sway bar brackets.
brolimo is offline
post #7 of 11 Old 01-22-2013, 08:30 AM
I know this is a very old thread but it addresses what i'm trying to do. I have a 97 f-250 hd (OBS) and i want to bolt up a new solid front axle. my question is what is my best option and is there a write up on this anywhere?
koskibd is offline
post #8 of 11 Old 01-22-2013, 08:34 AM
Quoted: 3 Post(s)
We have whats needed..pm-email me for info.
post #9 of 11 Old 01-22-2013, 10:43 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
What does it cost to put 08 axles in a 96 F350 front and back?
Phillipjon is offline
post #10 of 11 Old 01-22-2013, 11:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You gotta find a doner truck, new brake lines, u joint adapters. Carry can hook you up on what the doner truck don't have lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
