blinkers - Ford Powerstroke Diesel Forum
Old 08-13-2009, 03:06 PM
blinkers
k so my 4 ways work on the outside and itll pop up in the dash but when i do either blinker indavidually it doesnt work all the fuses are good. anyone have this problem? any ideas how to fix? i feel like such an a hole driving around with no blinkers cause no one knows had signals any more hahah
Old 08-13-2009, 04:32 PM
Did you check the turn signal flasher? It is different than the 4 way flasher. When you use the turn signals, does the light come on in the dash, and just not blink? or do they not work at all?
Old 08-13-2009, 05:26 PM
check your blinker fluid.
check\replace the flasher relay on the fuse panel.
Old 08-13-2009, 06:35 PM
nothing comes on at alli saw in the manual that i needed to replace the whloe unit but i think thats crap
Old 08-14-2009, 04:20 AM
i just saw the trun signal flasher this morning hahaha i skiped right over it when i was checking ALL my fuses! hahah im going to pick one up today see how it works out
