can i run B20 Biodiesel in my truck? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-09-2009, 08:51 PM Thread Starter
Rooster!!
Ravenwood Ranch's Avatar
they have it for sale here in las vegas, b20 only, question is can i run it with out any problems or do i need to do some type of conversion, currently im running reg diesel with Diesel kleen cetane boost, also i have 225,000 miles on my truck
Ravenwood Ranch is offline
post #2 of 14 Old 08-09-2009, 09:19 PM
back in the saddle
shu873's Avatar
Yeah you can run it no problem. I would suggest stepping up your fuel filter change intervals as the bio is a great solvent/cleaner and will loosen up anything currently stuck in your fuel system.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 14 Old 08-09-2009, 09:52 PM
wacko37's Avatar
does that apply to ALL bio diesels?
So far all i have is FBD 4" turbo strait back
6.5" Pro-Comp lift
Full stereo with a custom made sub box I built
Harley Headlights
Autometer gauges
SCT X3 with IDP tunes
BPD EGR delete and oil cooler
ARP Head studs
6.4L Banjo bolts
18" MT classic lock rims with 35x13.50 cooper STT tires
wacko37 is offline
post #4 of 14 Old 08-09-2009, 10:20 PM
orng1's Avatar
Quoted: 3 Post(s)
Yes applies to all bio diesel.
Bob
2001 F250 SRW Reg cab, long bed, 80k miles.
Now with DP tuner, Airaid intake and 4" Magnaflow turbo back exhaust.
orng1 is offline
post #5 of 14 Old 08-09-2009, 11:13 PM
wacko37's Avatar
thats freakin sweet!! i always thought you had to do something special to run that stuff.......
6.5" Pro-Comp lift
Harley Headlights
Autometer gauges
ARP Head studs
6.4L Banjo bolts
wacko37 is offline
post #6 of 14 Old 08-10-2009, 02:52 AM
TxAG'97's Avatar
So wouldn't it be a good idea to run a tank or two every once in a while to just clean it out? I had not realized there was no other modifications required to run the Bio.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip, Stage 1's, BTS
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear Replacement Clear Headlights
Ruff Tuff Seat Covers, Westin Nerf Bars
16x10 Pacers W/315 75x16 Duratracs
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
TxAG'97 is offline
post #7 of 14 Old 08-10-2009, 05:54 AM Thread Starter
Rooster!!
i wasnt sure, ive heard people running the b20 grade and b5 grade, and seeing that there a mix of reg diesel and bio i would think they would be ok, so has anyone here run it in the OBS PSD, and TxAG'97 i only have one thing to say, GO LONGHORNS!!!
post #8 of 14 Old 08-10-2009, 06:17 PM Thread Starter
Rooster!!
come on guys i just want to know what blends i can run in it, or if i need any mods to do so
post #9 of 14 Old 08-10-2009, 09:14 PM
guy here in boulder city runs his 01 7.3 truck on anything from hydraulic fluid to atf. he told me he hasnt actually filled up with diesel since the last long trip he took. so bio is no problem.
brolimo is offline
post #10 of 14 Old 08-11-2009, 03:35 AM
TxAG'97's Avatar
You better watch out with those comments we are looking better and better with every passing moment. Of course you can't get much worse than our performance last season but no matter how you look at it you t-sips are in trouble this year. You have to come to College Station to play some hungry AGs.
And oh I almost forgot Gig'em!
Most importantly
TxAG'97 is offline
