more power?!? - Ford Powerstroke Diesel Forum
Old 02-16-2007, 09:26 PM
more power?!?
i got 96 7.3 with 3in dp 4in ext 100hp tuner k&n air
what can ido to make it better beside fuel inj.
Old 02-17-2007, 03:46 AM
other than doing a turbo upgrade or nitrous or propane or water meth injection kit, nothing... if you are running stock injectors than your programmer is probely not giving you the full 100hp probely mor like 80 or so. i put some stage I injetors in my 97 and it absolutly hauls a$$ compared to before with just the mods like you have done. before i was getting around 23psi of boost wit my stock turbo and the mods you have and now i am easily buryin the needle on my 35psi boost gauge and still have a stock turbo.
Old 02-17-2007, 03:55 AM
BIG TRUCK, SMALL DRIVER
You can shim the Fuel pressure. Check this link out.
Tips - Idea - Hints
Old 02-17-2007, 04:00 AM
yeah i tried doin that before and after my injectors and it ran worse and actually shut off one time when i let off the go pedal while goin down a bridge. :drive:
Old 02-17-2007, 04:03 AM
what pressure did you set it at? Mine runs a lot better.
Old 02-17-2007, 10:10 AM
if you did the BB thing.you had it to far in.i did that on mine once.i just went to ford and got the CAL truck plunger kit.not as much pressure as the BB but it was more.it been a few years and i'm wanting to say it was around 58-60lbs with it.
Old 02-17-2007, 11:26 AM
One thing I would do would be to lose the k&n filter, especially if it is a drop in replacement. Try going with a tymar open element or an AFE intake like mine. Also getting a TWildman chip will make your truck run alot better Just my suggetions, good luck with your decisions
Old 02-17-2007, 11:35 PM
Nuckin' Futz
hey stroked is Tony paying you...you seem to like twildman's customs tunings
Old 02-18-2007, 12:23 AM
Consumer loyalty Turbodude hahaha, I'm the same way with my DP. But I know that the Twildman chips are top notch as well.
Gord.
Old 02-18-2007, 07:33 AM
i dont know wat the BB thing is. i made my shim from a little tiny nut and two tiny washers to meet the specs of the webpage i got the idea from. the page is an OBS tricks and hints page ive seen it posted on here from time to time. How thick does the shim need to be to give the most power gains without it shutting off or runing like crap?
