95 7.3 Runs away - Ford Powerstroke Diesel Forum
Old 08-03-2009, 11:13 AM
95 7.3 Runs away
My PSD runs away and clacks like crazy.... Any ideas ??? The tanks have been drained (One replaced) in the last 2 weeks and still the same problems.
Old 08-03-2009, 11:29 AM
duct tape & zip ties
Describe what it is doing when you say it is running away.
How are you stopping the engine from running. If your turning the key off and it shuts down then that is not a run away engine. If your removing the fuel or air from the engine, because it will not stop running when you turn the key off. Then you have a run away engine.
Did you mess with the fuel delivery system on the engine.
Old 08-03-2009, 12:01 PM
It will rev up by itself. Hold the brakes and it burns out. (Not a true run away)
Blows smoke like crazy and clacks like hell.
Old 08-03-2009, 03:31 PM
Thanks for the PM - I have checked the turbo and air intake for oil blow by. Very minimal and only at high RPM. I did find the oil to be a few quarts over full. I’m am sending out a sample to get it checked for fuel dilution.
Old 08-03-2009, 03:38 PM
Yep, its a 6.0
I knew powerstrokes had alot of power, but running away....put a leash on that thing
Well I hope you figure out whats wrong
Old 08-04-2009, 05:51 AM
let us know what you find out.
Old 08-05-2009, 12:05 PM
Well - I ran the Cylinder contribution test and did a buzz test with no errors. If the injectors were worn out by water in the fuel, would it pour fuel into the cylinders ? It is a interminten problem.
Old 08-05-2009, 12:13 PM
Throttle position sensor maybe?
Old 08-05-2009, 02:37 PM
I doubt it is the app because there is an idle validation switch that must be opened before the PCM allows any fuel enrichment. I would look at Mass fuel desired, and pulse width, icp as well as throttle pos. idle validation, to determine if the pcm is requesting the enrichment or if the fuel is coming from another source which is my guess due to it's being over full on oil. Have you adjusted the oil level, and does it still do it?
Old 08-05-2009, 07:26 PM
Now that you mention it, you're right. I hear mine 'click' every time I touch the go pedal. I wonder if the O.P. can verify the same.... ? Great point !
