changing oil - Ford Powerstroke Diesel Forum
Old 08-02-2009, 05:59 PM
changing oil
now this is going to make me sound like a huge rookie but id rather do it right. so im gunna change the oil in my truck and i got a 5 gallon bucket of rottela and it takes 14 quarts right? and also what about the oil in the 3 quarts in the hpop (does it need to be changed?) thanks.
Old 08-03-2009, 10:39 AM
14-15 quarts is right if I remember correctly. And there's no need to change the HPOP oil, just drain the pan, change the filter, and refill.
Old 08-03-2009, 10:40 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
only way to screw up an oil change is to forget to put the plug back in the pan
Old 08-03-2009, 10:47 AM
Send a message via Yahoo to carnival owner mikey
ive seen a procedure for evacuating and changing the hpop oil and the vid said the motor oil was fresh but the oil that came out of the hpop was NASTY!!. dont know how true this is and have allways wondered.it was on powerstrokehelp.com but the long and short is evacuate hpop, fill(about 1 quart),run truck for a min ,repeat, do this three times then fill hpop the last time with prolong or standadine or similar product. i myself have never done this and often wondered if anyone on the org has?
Old 08-03-2009, 11:12 AM
Old 08-03-2009, 11:31 AM
Send a message via AIM to nccatfan
It's often deemed unnessecary by the guys on this site (tho I'm sure it won't hurt anything to do so). That oil should mix with the rest of the new eng. oil after several minutes anyways. Also, start with 12 quarts on your '95, that's how much my old '94 took.
Old 08-03-2009, 11:55 AM
im goign to change my hpop oil the next time around. jsut cause. i saw that vid as well. figure it can thurt anything.
i always forget what i put in. i remember i changed something, like 14 qts, then thre remailing in the filter (more than a qt) or something to that effect. but finalyl i got a combo right, and i didnt overfill, and 4k later it was still full, as wher ebefor ei thoguht it was burning 1 to 2 qts between changes. but again, i always forget how that goes...
Old 08-03-2009, 09:15 PM
Changing / flushing the HPOP made a big difference in the 97. Over 3k and the oil is still golden. Smoothed the engine out a bit.
Old 08-04-2009, 09:43 AM
thanks for the info i changed the oil last night and it went great thanks.
Old 08-04-2009, 05:58 PM
what is a hpop? never heard that before
