Oil Pressure
What is the oil pressure on a 7.3L powerstroke not the high oil pressure side but like just normal pressure
oil temp at 170 degrees idle 18-20psi. 38-45psi at rated speed. Oil pressure should always be checked at operating temperature. However, the oil psi at a lower temp will vary to the weight of oil used. 35-60 psi from idle-rated speed at a cooler temp.
