vacuum pump - Ford Powerstroke Diesel Forum
Old 07-23-2009, 06:04 PM
vacuum pump
anybody know if there is a way to clean them up and make them work. mine is dieing on me all of sudden its not making vacuum very fast
Old 07-23-2009, 06:25 PM
Thats Mr. Oil Leak.....
I don't think they can be rebuilt. but not sure.
Old 07-23-2009, 06:34 PM
mine breaks every year the bearings blow out of them buy a lifetime warranty one from napa. i have a spare so i can fix it wen it breaks on the road.
Old 07-23-2009, 08:28 PM
Send a message via AIM to Maverick1701
I just had to replace mine too
Old 07-24-2009, 07:38 AM
Mine comes on all the time and the truck wont start untill the pump kicks off. Also right before the pump kicks off there is usually a light clicking noise from the dash. Never have been able to pin point it. It only does this after sitting for a while like over night. I have been thinking there is a vacuum leak but not sure what else could be causing this.
Old 07-24-2009, 08:18 AM
you sound like you are talking about the electric pump on a superduty. OBS trucks still use a manual belt driven pump. If yours is not starting when the pump is running check your battery cables for good connections. Also if you were have a vacuum leak problem your ac vents should default to defrost and not blow out of the regular vents.
Old 07-24-2009, 09:04 PM
Double post
Old 07-24-2009, 09:06 PM
I just replaced mine this week. 190k on the truck. Bought a new one from Napa. Only a 1 year warranty they claimed they don't make a lifetime pump anymore?? Mine blew out the bearings and snapped the shaft.
Old 07-25-2009, 07:01 AM
yeah when if u pump the brakes a couple times it the pedal gets really hard and the air blows threw the defost. Also when I start the truck it takes a little bit before the air blows threw the vents
Old 07-25-2009, 10:07 AM
i payed $155 for mine at napa, i bought them about 6 years ago. ive probably taken them back 7 times.
