ZF5-ZF6 swap? 95 F350 2wd.
Will it work and what does it require. 95 F350 2x4 drw ext cab. Best input gets a prize after 5 days from post. Of course I'll need your address.
Have you checked w/advanced adaptors? They might have a kit to do the swap.
shouldn't need any kind of adapter.
the only differences I can think of would be the change in the overall length of the trannies. don't know if one is longer than the other or not. if it is you'd need a longer/shorter driveshaft and maybe move the crossmember. tranny is same bellhousing bolt pattern. I don't know if the zf5 uses the same slave cylinder or not. if it is twist and pull to remove etc.. it should work. |
Thanks fellas.
