Fuel pressure - Ford Powerstroke Diesel Forum
Old 02-13-2007, 04:16 AM
Send a message via AIM to race14race
Fuel pressure
my truck starts then dies. thinking maybe fuel problem? i see a valve core looking thing on the regulator, i think its the regualtor, soo where/ how do i check my fuel pressure.
where r the pumps located at?
Old 02-13-2007, 04:21 AM
ADMIN AND TECH
should be a shrader valve on side of filter housing ,fuel presure should be 45 to 55 lbs will climbgradually while cranking
Old 02-13-2007, 12:07 PM
ok i checked it and cranked quite abit. and it got to 35 psi.. when does the fuel pump at the tank come on? with the key? it dont seem like its coming on
Old 02-13-2007, 12:35 PM
ADMIN AND TECH
Doesnt Have One In The Tank,fuel Pressure Seems Low To Me
Old 02-13-2007, 07:31 PM
your mechanical fuel pump is located infront of and below the turbo in the valley of the engine. You will probably have to remove your engine cover to see it if you haven't already.
Old 02-13-2007, 07:58 PM
7.3 tech, supporter
Sounds like fuel pump to me, not too bad to do, it can be done with the turbo in place just have to remove the bolts for the filter housing and pull it forward.
