pressure washing engine?? - Ford Powerstroke Diesel Forum
Old 07-20-2009, 10:07 AM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
Any problem with this?
I was planning on using superclean, or purplecleaner or simple green or something like that so i can thouroughly clean it and narrow down where my couple of tiny leaks are coming from!
Old 07-20-2009, 10:33 AM
bump....im curious too
Old 07-20-2009, 10:56 AM
Old 07-20-2009, 11:05 AM
me too
I wonder about steam
Old 07-20-2009, 11:06 AM
i have a crap ton and then some of gunk in front of the engine, and i would love to know where the oil is coming from. i suspect the hpop but want to be sure.
Old 07-20-2009, 11:11 AM
Send a message via MSN to Power-Stroked
Its okay to pressure wash ur engine. just make sure u dont turn the engine off and risking cracking the block. which is very bad lol. as long as u keep the engine running it maintains the temp and will do no harm to the engine at all. i do it all the time..at least 3-4 times a month down at the local car wash, i usualy degrease,rinse,rinse.
Old 07-20-2009, 11:35 AM
Send a message via AIM to nccatfan
I wash every truck engine before a PM everyday at work. Washed my own PSD eng too... seen somewhere to avoid washing while the eng is at or near operating temp (something to do with the fuel pump I think). Other than that, avoid the alternator and you'll be fine.
Old 07-20-2009, 11:41 AM
okay im going to go ahead and just wash mine down with a pressure washer and degreaser.. i dont have access to steam unless i go down to the local car wash.
Old 07-20-2009, 11:54 AM
what about it you have an open air fillter?
Old 07-20-2009, 12:08 PM
oh good call! i have the same intake you do! If you leave it running this probably isnt a good idea cuz it will just suck in the water...
Anyone who said to keep it running in order to not crack the block... can you just do the pressure wash when the truck is completely cold if im using cold water? That way i can put a bag over the air filter and seal that off
