ok......gauges installation time - Ford Powerstroke Diesel Forum
Old 07-15-2009, 07:13 PM
i have a pyro, water temp, and tranny temp. i need to know where each sensor plugs into. diesel manor said for the water is to take out the plug next to the tstat and put it there. ok, but i dont know where is a good spot for the pyro and tranny sensors. ill get better pics tomorrow of the gauges and parts. if yall have pics, post em please.
Old 07-15-2009, 07:32 PM
Tranny temp probe goes on the drivers side of the trans. If you crawl under you will see a plug right above the split seam for the pan. Your probe should thread right in. dont worry about fluid loss, not much comes out. For the pyro I installed on the drivers exhaust manifold, drilled at the lowest point, hole facing down. I think its a 11/32 drill bit then tap with a 1/8 NPT. Use grease to hold the shavings and go super slow when your about to break through. was kinda easy. Whole project (pyro,trans,boost) took me about 6hrs. Hope this helps good luck
Old 07-15-2009, 07:33 PM
Shaking the Bush Boss
Old 07-16-2009, 11:26 AM
tranny
pyro
water
and each on of em has this
so where do you hook up that box? do you tap that into the ignition or just have it hot all the time. if so what about the batt drain?
and for the lights, i was gonna tap into the switch. so what wire do i do for that?
Old 07-16-2009, 04:44 PM
this came today
im glad fedex can ship a box without crushin it.
boost
Old 07-16-2009, 05:45 PM
and for the turbo, how does that connect?
Old 07-16-2009, 06:55 PM
I pulled of my intake and drilled and tapped it for a fitting
Old 07-16-2009, 07:16 PM
Electrical Ogre
You can t-tap the MAP sensor hose for boost. Look for a lt-blue/red stripe wire for gauge illumination.
Old 07-17-2009, 12:13 AM
ok got the gauges mounted and the lighting done. and ran the wires down to under the dash. the sensors will have to wait till sat. just need to find a spot to mount those boxes. i like the t fitting on the map better than the intake manafold. its already on the engine and i dont want to take the time to reseal it. that mounting was a pita.
now i just cant wait to power em up.
wheres a good spot for the power to tap into? the lights in the gauge looks great!
Old 07-17-2009, 02:56 AM
advise not to use grease
Drilling the Exhaust Manifold....SCARED
