Mud Flaps - Ford Powerstroke Diesel Forum
Old 07-13-2009, 06:25 PM
Nuckin' Futz
Mud Flaps
Those of you who have aftermarket mud flaps on your trucks how did you mount them. I like the ones which are mounted to the rear bumper rather than on the rear of the rear wheel wells but i don't like the ones that are attached to a receiver hitch. i don't know if i should run a chain across the underside of the bumper or a piece of angle iron. there is two holes drilled on either side of the bumper but im curious as to how it was rigged up. i figure you guys could give me some insight.
Old 07-13-2009, 07:16 PM
drill and bolt them. use nylock nuts and a piece of angle aluminum.
Old 08-06-2009, 02:23 PM
I make custom kits that mount on the frame and the bracket stays secure, but the flap is fully removable for off roading. PM if your interested in more info
