Please Pray for Matt P's Truck
Matt P's truck is currently in surgery right now. He is replacing his stock turbo
for a D-66. The problem is his bolts are stuck and some are stripping out. Please pray that he can finally get that truck back together. |
Oh Matt thats horrible buddy
![]() My deepest sorrow goes out to you and your mechanical skills ![]() ![]() ![]()
Our prayers are with his truck. man that sucks you know sometimes you just need to give it a rest for a hour or so and things will go better.
I think he is about to give up
Can't he just grind the heads off the bolts, pull the turbo, then use a vice-grips to pull the bolts?
I believe the turbo is bolted down to a pedestal isnt it? Grinding off the heads would make it impossible to remove
Im not sure. If you could grind the heads off you could slide the turbo up and then unthread the remains of the bolt.
\But dont get me lyin, i dont know a thing about turbos other than they push air lol |
O nevermind then.
lets just hope things do go better for him
