stage 2 Injector build - Ford Powerstroke Diesel Forum
Old 07-11-2009, 02:08 PM
I recently bought the Stage 2 build kit from Jim and i was wondering if anyone knows anyone around the Indiana area that knows how to build these and where they are at.
Ive also ordered a TS chip and a 4" TB exhaust to add to my list. I know I will need the chip re-tuned to run these injectors the right way.Anyone comment...
Old 07-11-2009, 02:09 PM
Shaking the Bush Boss
bump to the top for ya....
Old 07-11-2009, 02:11 PM
i built mine myself. there not flowtested or anything. were you looking for some help? im not to far from you.
From what I understand, the kit comes with good instructions and everything you'll need to rebuild them yourself.
Old 07-11-2009, 02:18 PM
I dont even want to attempt it. Everything I touch gets messed up, I swear I am cursed. I am looking for someone to pull my injectors build them and put them back in and someone that knows what they are doing. I just dropped down $700 for the kit and all the other stuff so I am a little low on cash but give me a couple weeks and Ill be back up. Ill pay you well if you can do it right.How far is Middlebury from Elwood,IN?
Old 07-11-2009, 02:21 PM
Ya dude dont be scarred. the instructions will walk you though every step. Did you get the pre machined pistons?
Old 07-11-2009, 02:22 PM
No I didn't. Should I have got them? What machining has to be done. I am friends with the guy's son that owns Iron Diesel up here. Ive heard he does good machining
Old 07-11-2009, 02:38 PM
you should price them out. in the cd you got it has a pdf file that will tell you what you have to do. if you take it to you buddys shop they should be able to tell you what they will charge. i think jim is asking 225 or so pust 50 core. they should be done on a flat grinder.
Old 07-12-2009, 10:24 AM
yea i can do them for you for cheap. it is pretty scary at first elwood would be a little less then 2 hours. as far as the flow matching. they just get the flow rate the same. all that is is just so each injector is putting out the same amount of fuel. you will get more hp if they are flow match. but i dont have mine matched. but yea let me know i can help ya out
Old 07-12-2009, 10:48 AM
Sounds good. Ill let you know in a couple weeks. Im definatly wanting to have them done before The Shied Extravaganza. Ill keep in touch with you
