installing new injectors on thurs - Ford Powerstroke Diesel Forum
Old 07-10-2009, 09:43 PM
picked up a set for 850 with no core charge. im a first timer at this. seems pretty straight forward. are there any tricks? is that tool to install them really necessary? guy told me about the little vacuum reservoir on the heater box so the 2 rears will come out easier. any tricks? Thanks a lot.
Old 07-10-2009, 09:50 PM
yeah a ratchet you sockets an extension with a swivel end....(for the valve covor).........a rubber mallet and a pri bar and you got all you need....
Old 07-11-2009, 06:41 AM
a truck
yep take the vacuum reservoir off, and there is no need for the special tool, when you put them in just be sure they are fully seated and be sure to purge all the oil out of the cylinders
Old 07-11-2009, 06:45 AM
Shaking the Bush Boss
Yep, thats it!!!!
I purged the cylinders by removing the glow plugs, and bumping the engine over....makes a good mess...even with the valve covers sitting in place...
Old 07-11-2009, 07:02 AM
yup they all nailed it. make sure that you get all that oil out of the cylinder, otherwise you will hydrolock the engine.
Old 07-11-2009, 08:01 AM
The easiest way to prevent making a mess is get a 1/4 hex socket and take the 2 oil rail plugs out on each head to drain the oil before removing the injectors. You may have to tap the socket in to make sure it is seated so you don't strip the plug. All the oil will drain to the pan.
Old 07-11-2009, 04:46 PM
that may be the cleanest way but not the easiest.....haha my first go around doin this i had all injectors out and no valve cover on and rolled the engine over....haha my brother started cussin and took off haha.....i shot it all over the shop wall about 5ft away....all over the car hoist haha....needless to say dad wasnt happy....
Old 07-11-2009, 05:31 PM
lol that sounded like a great time.
