cam sensor/turbo suge 2 questions - Ford Powerstroke Diesel Forum
Old 02-10-2007, 03:35 AM
Hello everyone I am new here nice sight alot good info.I have a 96 model 7.3 powerstroke f350 5 speed bone stock.everyone says to keep a cam sensor in glove box I checked on ebay but they are giving the same part number for all year models confusing i thought they would change through the years.any info on the part no. i need ? Question #2 what is turbo lag and surge and what does it do .Thanks
Old 02-10-2007, 05:13 AM
BIG TRUCK, SMALL DRIVER
I have never had a Cam sensor go bad, but I do have an extra, justincase!
Turbo lag refers to the time it takes the turbo to spool up and create boost. Some take longer than others depending on setup. Lag should not be a problem on your truck.
Turbo surge is when the air flow in the turbo gets out of wack. Ths is just a turbo efficiency thing. It is common in the later modle trucks when under load. You should not have a problem with this either.
Old 02-10-2007, 05:58 AM
duct tape & zip ties
the cam sensor maybe the same for all years. I say this because the cam sensor is on all powerstrokes with a 7.3L I wouldn't be surprise if they are all the same. A cam sensor is a cam sensor just like a duck is a duck.
Old 02-10-2007, 03:31 PM
Thanks guys ,for all the info.
Old 02-11-2007, 07:18 PM
I'll be interested in seeing the input on this one. I've read a lot of opinions on the CPS so far on here. One said that 96 back used shims that aren't needed any more, another said 97 up used a different material in the pins and there could be a corrosion problem if you mismatch years. One said the CPS from a dt466 will work but it retards timing a bit. I do know there are different part numbers for 97 up on these.
Old 02-16-2007, 05:55 PM
early ones had different metal pins than the later ones, they work but could cause corrosion because of the dissimilar metals but they will work, and the blue international 466 ones do retard your timing and work but aren't the same as the ford black ones
