Truck dies - Ford Powerstroke Diesel Forum
Old 02-09-2007, 08:27 PM
Send a message via AIM to race14race
Truck dies
i just bought my 94.5 psd and it will start and run then die and not it will not even start. its been kind of acting up. is this the cps? i understand if the tach doesnt register its a bad cps but how much does the tach move?
Old 02-09-2007, 09:58 PM
Nuckin' Futz
Any codes? Did you check you fuses? The tach wont read at all if the CPS is bad because basically the CPS is the only thing that lets your ECM know that the engine is running. Check your fuses and see if it has any codes...they could be the problem. If not let us know and we will keep hacking at it.
Old 02-10-2007, 04:42 AM
well i checked fuse number 22. it wasnt bad. the truck will crank and maybe hit a lick ever once in a while.. but it is in the teens at night and up to about 30 in the day..before it died the check engine light came on.. but it started up sense then but now it wont start again. the tach DOES move though and its supose to have new glow plugs
Old 02-10-2007, 04:44 AM
ADMIN AND TECH
check oil level and is it in good shape
Old 02-10-2007, 05:20 AM
BIG TRUCK, SMALL DRIVER
Are the batteries good?
Old 02-10-2007, 05:41 AM
yes batteries r good. the oil prob needs changing but i would guess its good enough to start
Old 02-10-2007, 05:57 AM
try checking fuel pressure while cranking?
Old 02-11-2007, 02:51 PM
the hpop keeps draining somewhere, i dont know where because after i crank it it is low or empty?? thats y it wont start?
does anyone know how much oil it is supose to hold?
