Rearend gear ratio - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-08-2007, 10:44 AM Thread Starter
Chad T's Avatar
Rearend gear ratio
Sorry guys but how do you go about finding the Rearend gear ratio? 97 7.3 PSD
Chad T is offline
post #2 of 11 Old 02-08-2007, 10:51 AM
duct tape & zip ties
bigcountrysg's Avatar
Unless it has been removed or broken off there should be a tag on the diff that tells you the gear ratio. If not you can go to a dealer and they should be able to run the vin number and tell you what gear ratio you have.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 11 Old 02-08-2007, 11:07 AM
cblackb's Avatar
Another good way is to jack the back wheels up. Mark the driveshaft and the inside of the one of the wheels. See how many times the driveshaft turns to get the tire to turn one complete revolution. Example: if driveshaft turns just a little more than 4 turns to the tires one turn..you've got 4:11's...3.7 turns?..3.73's...3.5 turns? ..3:55's.
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
post #4 of 11 Old 02-08-2007, 01:33 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Look at the sticker in the driver side door jamb. Under axle it will have a 2 dig. code. Let me know what it is and I will look it up.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #5 of 11 Old 02-08-2007, 04:18 PM
Nuckin' Futz
its probably 3.55 thats what mine is.
Turbodude is offline
post #6 of 11 Old 02-08-2007, 05:35 PM
International Threat
Marty's Avatar
above methods work let us know.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #7 of 11 Old 02-08-2007, 08:48 PM
therealdgh's Avatar
Send a message via AIM to therealdgh Send a message via MSN to therealdgh Send a message via Yahoo to therealdgh
pipelayrjdh, do you know what a C9 axle code is? That's what I've got on mine.
1997 F-350 CC LB 4x4 7.3L 270,xxx+ miles
Goodyear Wrangler SilentArmor 285/75R16
Casserly Stage I injectors
Schaeffer oil
IDM (Injector Drive Module) mod
Borgeson steering shaft, Red Head steering gear
therealdgh is offline
post #8 of 11 Old 02-09-2007, 12:05 PM
6,250 lbs. capacity w/ limited slip
Derrick
post #9 of 11 Old 06-22-2007, 01:56 PM
I'm looking at buying an 89 F350 parts truck and the guy said the axle code is 39. What would that be? I thought the first number in the code was always a letter?
Tony1784 is offline
post #10 of 11 Old 06-22-2007, 02:08 PM
jphelzer's Avatar
39 Conventional non-Positraction Differential 3.55
2001 F250 Ext Cab LB 4x4
7.3L PSD, 4R100
Stock except for DIY Tymar intake and 4" exhaust
226K miles and counting!
jphelzer is offline
