| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
lights and wiring
Okay i have a basic visor on my truck with the 5 orange lights. I might be sounding dumb but i dont know the name for it other than a visor on the cab. Anyway the other day i lost all power to it (or so i think). None of the lights work anymore (i dont think they would all burn out at once) how can i go about testing if there is power up there or is there a fuse to check or what?
The Visor is more than likely a LUNAR or MOON Visor from LUND. And if you dont have cab lights, then there is a wire that is ran from the visor, down into your dash somewhere. Pull out your A-pillar trim, and see if there is a wire behind one of them, more than likely it'll be on the drivers side.
It'll more than likely be tapped right into the parking lights, but where, who knows. It may have a fuse in line, but I dont know for sure, Just gotta do some tracing with a test light! |
Make sure that wire isnt broken anywhere. And if its run into the fuse panel, then thats a bad idea ( i've done it ) But it should be spliced properly into a wire, WITH a fuse.
If you dont have a test light, you should buy one, they are a few dollars, and worth every penny if you want to do this kind of stuff yourself. Use it, ground the clip on the light, and poke the wire (not your finger!) with the marker lights on. if you get power there, then its a ground issue. Its possible that the wire has lost contact from the fuse it was spliced into, OR that you lose the ground for the lights. Check the visor, and make sure it has a good ground for the lights. |
yeah i would check the wire isn't broke that runs inside door rubber over time with the door closing on it it may have cracked split etc.
Stick it in there till you are positive you've got a good connection, it wont take much.
Well, if you do NOT have power at the wire, then keep tracing it until you figure out where its lost its connection. OR, Run a new one. |
Depending on how your lights are wired in the visor if one burns out it breaks the circuit and they all go out.
how can you tell if its like this just by looking it at it? like is there a noticable difference in the wiring between the bulbs?
