| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
Camber bushings
I am leveling my 96 250 PSD 4x4 and need the part numbers for the moog bushings required and cant find it with search feature....anybody help a brotha out
Camber Bushings? Got a picture, of where on the truck these are?
I dont have a pic...I remember reading a thread that called out the Moog part no. for bushings to restore the stock alignment specs after installing a set of leveling springs.....
ANYONE!!!
need some help here
I would say talk to your alignment shop
![]() I think that is your best bet! |
Found some on E-bay and it says the part number is K 8284. I am not a parts man so I don't know for sure.
Ck for youself.moog Camber bushings - Google Product Search Hope this helps. Doug |
Moog Part #
Depends on how much adjustment you need.
PROVIDES UP TO 2 3/4 DEGREES PLUS OR MINUS K8709 w/BALL JOINT SUSPENSION 0 DEGREE PLUS OR MINUS K8958 w/BALL JOINT SUSPENSION 1/4 DEGREE PLUS OR MINUS K8959 w/BALL JOINT SUSPENSION 1/2 DEGREE PLUS OR MINUS K8960 w/BALL JOINT SUSPENSION 3/4 DEGREE PLUS OR MINUS K8961 w/BALL JOINT SUSPENSION 1 DEGREE PLUS OR MINUS K8962 w/BALL JOINT SUSPENSION 1 1/4 DEGREES PLUS OR MINUS K8963 w/BALL JOINT SUSPENSION 1 1/2 DEGREES PLUS OR MINUS K8964 w/BALL JOINT SUSPENSION 1 3/4 DEGREES PLUS OR MINUS K8965 w/BALL JOINT SUSPENSION 2 DEGREES PLUS OR MINUS K8966 w/BALL JOINT SUSPENSION NEW DESIGN 2 1/4 DEGREES PLUS OR MINUS K8967 w/BALL JOINT SUSPENSION NEW DESIGN 2 1/2 DEGREES PLUS OR MINUS K8968 w/BALL JOINT SUSPENSION NEW DESIGN 2 3/4 DEGREES PLUS OR MINUS K8969 Got this of of the Moog Web site. Part no's are for a 96 F-350 4X4 Good Luck Rick |
Many thanks
there was a thread on here that was pretty specific right down t the alignment specs...this gives me a good starting point. If i remember right it req'd 1.5/2 degrees after the 2" spring was installed. After looking a 2" drop piman arm might be helpfull as well, just to make averuthing as close to stock as possible.
