35's on 96 F350 - Ford Powerstroke Diesel Forum
Old 02-09-2009, 06:55 PM
Question 35's on 96 F350
do I have to put a leveling kit on it to run 35's
Old 02-09-2009, 06:56 PM
yes you have to have a leveling kit to run 35s
Old 02-09-2009, 07:04 PM
No you dont need a leveling kit, i had 315/75 R16's on my truck when it was stalk height they just rubbed the leaf springs at full crank, so you need wheels that are spaced out a little but other then that they fit fine.
Old 02-09-2009, 07:08 PM
You need a leveling kit or get stupid looking wheels sticking out too far...you need the leveling kit. On my 97 250, I put a 2 1/2" lift on with 33x12.5 16.5 tires and I had to cut a small part of my bumper off.
Old 02-10-2009, 02:24 AM
can I get some small blocks for the back if I get a leveling kit?
Old 02-10-2009, 06:01 AM
97 F350's sit higher then 97 F250's, you should not need a leveling kit, and even with a leveling kit your tires will still rub the leaf springs, so you will still need to have your wheels spaced out.
Old 02-10-2009, 06:16 AM
right now my 94 has 36.5's on it with no lift ( i used to think it had a little but after looking at it closly it doesnt) the frotn bumper is spaced out from where the previous owner had a winch on it though
Old 02-10-2009, 10:51 AM
Smile
I have a 95 f350 with no lift and 35s fit with no problem. I did have to cut about an inch off the front bumper. I cut on an angle and it looks factory.
Old 02-10-2009, 05:07 PM
it looked like I would have room I have 305's now. pushinA95 do your tires rub?
Old 02-10-2009, 05:08 PM
and Thanks for the info!!!
