body lift for a diesel f350 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-30-2009, 05:17 PM Thread Starter
Lightbulb body lift for a diesel f350
when i had to remove my turbo for a repair i had to jack the body up to get access to exhaust bolts. it was not fun. a body lift would give me the extra room i want for making repairs. however, when i look for one for my truck they all say EXCEPT DIESEL. why can i get a lift for a 460 but not my diesel? anybody been down this road before me and come across a solution?
94 DI turbo... all stock except the wheels and air filter
ir1680 is offline
post #2 of 6 Old 01-30-2009, 05:31 PM
Shade tree mechanic
95dieselsmoke's Avatar
I have a body lift on mine, but ti was on there when i bought it.... IIRC i believe the kit for the gassers works just fine on a diesel... and the extra room is sweeeeeeeet
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #3 of 6 Old 01-30-2009, 05:31 PM
Foamy's Avatar
Because you would need to rework all the intercooler tubes and what not.
2006 F250 Harley Davidson
Traded in for a 2011 Dodge Ram 2500
6.7 Cummins, Mega Cab, 6 speed Manual
For sale, SCT x3, Unlocked, 6000k h13 HID kit
Foamy is offline
post #4 of 6 Old 01-30-2009, 05:33 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
On a newer truck thats true. But no intercooler on an OBS.
You can do a body lift on an OBS just not on a newer truck
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 6 Old 01-30-2009, 05:33 PM
duct tape & zip ties
bigcountrysg's Avatar
No, just need to make mounts to keep the intercooler in stock location. You have to do it, for the radiator as well. When you do a body lift your moving the location of the coresupport as well. So to realign the radiator with the engine you have to drop it down.
I prefer not to use body lifts. For many reasons, mainly they put a lot more stress on the body mounts of the truck.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #6 of 6 Old 02-08-2009, 03:58 AM
hijo202's Avatar
I made my own body lift, it was alot cheaper than buying the glass impregnated blocks. I found a guy on e-bay that sold solid aluminum rods - 4" in diameter, and had him cut them 1.5" tall (12 total if memory serves me right). I just drilled a hole through the middle of each one & got bolts the length I needed (all grade 8). I had to replace most of the rubber bushings anyway, so I did it all at the same time. It took me about 4 hours total to do all of them. The only issue you will run into is the bed, if you use it like I do to haul heavy items. You will see under it, that there are support rails that support part of the bed, but are not bolted to it. I used square tubing and bolted it to the frame and the bed now has all the original type supports. It made a huge difference on cabin noise (didn't get the pinch weld moved enough for the down pipe, so it was rubbing at times). You have to trim a little (depending on how high you lift the body) the lower radiator fan shroud to clear the fan and that was it. Now the body lines are correct and it looks great!! I hope this helps.
'97 F-250, 4x4, Supercab, D60 Swap, Intake, Turbo Back Exhaust, TW 6 pos, IDM Mod, HPX, FS 2500 Oil Bypass, Quadzilla Recon XZT Digital Gauge, RSK w SD springs, 1.0 compressor housing, EBPV delete, modded pedestal, E-fuel with "Tight-wad" regulator mod
hijo202 is offline
