Best paint to use on rusted frame? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-02-2014, 08:41 PM Thread Starter
bdemutis's Avatar
Quoted: 8 Post(s)
So I took my bed off today eliminated the second gas tank because there was a hole in it started taking the shackle mounts and shackles off before it started to rain. Well my question is what is the best to use on a rusty frame. I'm going to use a high powered pressure washed knock off all the heavy rust. Then I was going to use my spray gun and spray everything while the bed is still off. I need something that is spray able out of a automotive spray gun last time I under coated a truck I used aerosol cans but then I bought a spray gun because I painted my truck so I don't know what to get. I seen something before at eastwood when I was there called frame restore. What's good to use?
bdemutis is offline
post #2 of 6 Old 07-03-2014, 07:14 AM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
There is POR-15, RustBullet, and others. They usually aren't cheap and I know with the POR-15, it needs to be top-coated since it is not UV resistant (not that it is going to see a lot of sunlight in your case). You can spray it or brush it on (it flows out well). Cheers!
Patrick Feeley is offline
post #3 of 6 Old 07-03-2014, 10:52 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
While I use POR15, I do NOT believe their claims (or others) that you paint over rust. I sandblast, POR15, then top coat with tractor paint.
I have had Very good success with this process on plow trucks
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 6 Old 07-03-2014, 10:54 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 6 Old 07-03-2014, 12:28 PM Thread Starter
bdemutis's Avatar
Quoted: 8 Post(s)
I might sandblast it or wire wheel it the only sandblaster I have access to is my gf's dads and I would have to get his big tow behind compressor because his sandblaster will only run off of that.
bdemutis is offline
post #6 of 6 Old 07-04-2014, 04:45 AM
Quoted: 4 Post(s)
The problem with a wire wheel, is it polishes the metal. And it also moves contaminants around the whole frame. POR and the like need a Rough surface to adhere to. The wire wheel on a grinder does NOT leave a rough surface.
Then you need to use the metal ready and marine clean as well
