95 F350 2 wheel drive front end left - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-28-2014, 12:38 PM Thread Starter
pk64f100's Avatar
I am looking at raising the front end about 2" or a total lift of 2"-3". I like the front a lttle higher may be from age dont know but sure would like the look of a little lift. Can anyone steer me in the right direction for a 2 wd CCLB? I dont know if I need a suspension or just a body left, I think body may do it but too sure. Thanks
pk64f100 is offline
post #2 of 6 Old 08-13-2014, 05:46 PM
7.3workacholic's Avatar
A gasser lift will work fine, it just won't sit as tall because of the added weight of the diesel, check out cp trucks, they have a leveling kit.
1997 F250 7.3 E4OD Centurion XLT 2wd, afe prodry s intake, diamond eye down pipe dump, tonys tunes, fpr shim, swamps idm, de-stickered and molded, smoked headlights,heavy duty rear suspension, Gearvendors, 2in level, 18in xd hoss on 35in terra grapplers, 8x8 steel rear bumper, in the process of black on whiting her
7.3workacholic is offline
post #3 of 6 Old 08-13-2014, 06:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The gasser lift needs more strength, I've literally seen the extending parts for the tib snap
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 08-13-2014, 06:25 PM
I called rough country, they said as long as I don't do any serious off tossing I should be okay, there is a guy on here somewhere with a gasser lift on his eclb, but once I get it on I will figure out some gussets to weld on the I bream drop brackets, that should toughen it up.
post #5 of 6 Old 08-13-2014, 06:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
My buddy snapped his while towing on the interstate in Texas, he has since added a gusset to the drop brackets and has been problem free since
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 08-13-2014, 07:28 PM
I think thats what I will do, hopefully going to install this weekend, the rivets holding the stock radius arm bracket are going to be a spin to remove.
