super swamper and rim question - Ford Powerstroke Diesel Forum
Old 01-05-2009, 01:50 PM
i have a 94 f350 dually with the powerstroke diesel motor.
I plan on lifting it 6 inch.
I am thinking of putting 35 or 36 inch super swampers that are 12.5 inch wide but i was told that our stock dually 16x6 rim is to narrow. I can not find any wider rims to do this. how are you guys putting super swampers on your dually's? Can I use the stock rims? Do i have to buy custom rims? Where can i get these rims to do this? and what tire size should i go for with a 6 inch lift. Any advise or opinions would be great!
Old 01-05-2009, 02:53 PM
I am running Rockstars which I think are a 1/2 inch wider and have no problems. One of my cousins has 38 x15 x 17 boggers and all he has is a 4" spacer in the rear. BTW i am not running a spacer on my truck.With 6" I would go with at least a 38 and trim what ever rubs.
Old 01-05-2009, 02:59 PM
Im running 37/12.50/17 Super Swamper SSRs on my stock wheels with 2 inch spacers in the rear and a 8 inch lift. I've had no problems at all.
Old 01-05-2009, 03:00 PM
Remember he has an OBS it could be different then the SD's.
Old 01-06-2009, 05:49 AM
So if i put 37x12.5 or 38x12.5 on a 16x6 rims with the 6 inch lift i should be ok then right? I might get a 2 inch spacer in the rear just for extra comfort.
Old 01-07-2009, 10:14 AM
You will definatly need the 2 inch spacer in the rear. You might even need a one inch spacer in the front. I'm not real sure on an obs. Cant wait to see pics!
Old 01-09-2009, 02:31 AM
so i talked to the tire and rim place today and they will not put a 36x12.5x16 tire on a 16x6 rim. they said the rim was to narrow.
So now i guess my question is where can i buy rims that are 8-10 inches wide to fit my dually?
Old 01-09-2009, 11:17 AM
I don't know of anybody that makes a 10 inch wheel for dually. Who are you trying to get to mount those tires? keep looking around somebody wiil do it for you. I just had a new set put on yesterday and nobody ever asked any questions.
Old 01-09-2009, 11:26 AM
you can run 315s on your stock wheels just get spacers
Old 01-09-2009, 11:38 AM
Send a message via AIM to IH06Pwrstrke
If you are set on running swampers, have you ever heard of the swamper LTB? these are designed for duallys. and vehicles with narrow tires. I see they make a 34x10.50 for 15, 16, and 17 inch rims.....the smallest rim you can fit a 12.50 comfortably on is a 8 inch wide wheel...these 10.50's ought to fit well on the 6 inch wheel
