Fuel Tanks - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-24-2014, 08:36 PM Thread Starter
firsttofight11b's Avatar
Fuel Tanks
I just got a 97 F250 ext cab and am trying to figure out the size of the front and rear fuel tanks for mileage purposes. Does anyone know?
firsttofight11b is offline
post #2 of 11 Old 05-25-2014, 03:05 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Should be 19 gallons up front and 18 in the rear. But you don't need this to figure out milage.
It should be listed in the owners manual too
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 11 Old 05-27-2014, 05:31 AM
Quoted: 50 Post(s)
What bed? Front - long bed 19 gallons, short bed 16 gallons. Rear - 19 gallons.
Of course, none of this is relevant to mileage.
madpogue is online now
post #4 of 11 Old 05-27-2014, 07:37 AM Thread Starter
Its a shortbed. Thanks!
post #5 of 11 Old 05-31-2014, 09:30 AM
vandy's Avatar
Really 19 in both for 38 total in a long bed? I ran my front tank pretty low (gauge wise) yesterday. I was sweating it for a min. Put just over 15 gal in the front. Guess I had more wiggle room
vandy is offline
post #6 of 11 Old 05-31-2014, 09:36 AM
Quoted: 50 Post(s)
If you ever like to run either tank that low, make SURE you have about 1/2 tank in the other tank. Common problem - the strainer on the pickup (aka "showerhead") cracks or falls off, and the pickup can't pick up any fuel below about 1/4 tank. So at about that ^^^^ level, the truck starts to die from no fuel. You have to switch tanks RIGHT away.
post #7 of 11 Old 05-31-2014, 09:43 AM
vandy's Avatar
Wonder if that's what's up with my rear tank. Just below 1/4 tank is EMPTY. I know because my 2 year old swapped tanks playing in my truck. Next morning I thought I was on the front and started sputtering.
Add one more thing to the list of things to do lol
vandy is offline
post #8 of 11 Old 05-31-2014, 11:26 AM
Quoted: 50 Post(s)
Depends on what happens when you fill up. If it takes pretty close to 19 gallons when this happens, then you're drawing all the fuel, and your gauge is just inaccurate. If you only get, say, 13-14 gallons in, then it's prob. the pickup.
Lucky that's all he did. My high school physics teacher told a story about his 2YO. Leaving the house, dad forgot something, left the car running in Park in the driveway and ran into the house. Kid climbed over the seat, pulled the shifter (column) down into Drive, car plowed THROUGH the garage door and car finally came to rest after poking halfway through the back wall of the garage. This was the '70s, before BTSI.
post #9 of 11 Old 05-31-2014, 09:00 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I went to fill my front tank the other day after winging it pretty low for a while, stuffed 19.3 gallons in the front, and 17.6 in the rear, guess I was about out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 11 Old 06-09-2014, 06:06 PM
Shaun (yota)'s Avatar
Is there any fixes for the pick ups in the tank?
Shaun (yota) is offline
