Clearing 37" - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-18-2014, 12:12 PM Thread Starter
xelaescal's Avatar
Clearing 37"
I am looking to lift my truck. I was wondering how high of a lift I would need to clear 37". I think I need a 6"m but was wondering if I could possibly clear them on a 4"? And what lift is a good a one. I want to do a suspension lift.
Thanks for all the help
Alex
xelaescal is offline
post #2 of 6 Old 05-18-2014, 01:44 PM
brockadams2002's Avatar
I have a 8in lift with 37's and still rub when turning hard..
2005 F-350 lariat , 6.0, crew cab, long bed, 8in Rize industries lift, 37in toyo MT on 22" Fuel rims. RCD EGR delete, "Zoodad mod."
brockadams2002 is offline
post #3 of 6 Old 05-18-2014, 10:05 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
at full lock you will hit the spring unless u set the steering stops , i have a 6" with 37's and clear them fine and i even put 40's on sometimes and clears them , just hits the spring when turning , you should be able to squeeze them with a 4" but it will be tight
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 6 Old 05-18-2014, 10:24 PM
joebuck's Avatar
Quoted: 35 Post(s)
I have a 6" lift and 37s on my 01,and I rub when turning hard,not to bad though,4" would be pretty close
joebuck is offline
post #5 of 6 Old 05-19-2014, 07:14 AM
mjones3586's Avatar
Im running a 4" lift and 36"s and hardly rub at all very rarely has to be at full lock with some flex
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #6 of 6 Old 05-19-2014, 09:40 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you want a great ride quality that will flex then you need a RS kit and SD lift springs..7-8" min to clear 37" on 9-10 rims. You should plan on crossover steering kit.
We have everything needed PM me if I can help.
CT Performance, Inc. is offline
