rust proofing - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2014, 08:37 PM Thread Starter
97bigblack's Avatar
rust proofing
Is there any simple product that I can spray on everything under my truck that will prevent rust and also help eliminate sound? I have used por-15 but that stuff destroyed my wallet
Thanks for all the help!
97bigblack is offline
post #2 of 4 Old 05-02-2014, 07:56 AM
Where are you from? you can try Krown Rust Control| Rustproofing & Protection for Cars, Trucks, Vans depending on your location. If you want to do it yourself you'll need a good spray nozzle and really get under there.
JamieH4 is offline
post #3 of 4 Old 05-12-2014, 05:28 PM
leojr's Avatar
Quoted: 4 Post(s)
I've read about Fluid Film Fluid FilmĀ® | Corrosion Preventative, Lubricant and Rust Inhibitor being rather easy to apply but haven't pursued it yet.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #4 of 4 Old 05-12-2014, 07:01 PM
Quoted: 48 Post(s)
Fluid Film is extremely effective for rust prevention. Does require re-application at times. Does nothing for noise. To reduce noise inside the cab, work inside the cab (Dynamat, etc.).
madpogue is offline
