Help with traction bars - Ford Powerstroke Diesel Forum
Old 11-30-2008, 04:19 PM
Send a message via AIM to Powerstroke7.3
I want to build a set of traction bars for my 1995 extended cab f-250. Will you all that have them post pics of your set ups. Thanks
Old 11-30-2008, 04:29 PM
im fat and ugly
home made traction bars
Old 11-30-2008, 04:36 PM
Big Daddy!
Nice Bars Stump!
Old 11-30-2008, 04:40 PM
im fat and ugly
thanks bud
Old 11-30-2008, 04:46 PM
Big Daddy!
I just sent the link to a buddy, I think we are going to attempt to build a couple sets ourselves! We will be using the STUMP blueprint!
Old 11-30-2008, 04:48 PM
im fat and ugly
cost ya 2 cases of natty good luck
Old 11-30-2008, 04:52 PM
Big Daddy!
No Problem. Next Time I see ya you remind me.... I'll hook ya up!
Old 11-30-2008, 05:02 PM
im fat and ugly
gotcha!!!!!!
Old 11-30-2008, 05:15 PM
stump - ya got a nice setup, but theres a couple things i noticed that may be an issue down the road, may not depending on how you drive. I ran into similar problems building my suspenion on my 150 from the ground up.
1. be careful welding a flange to the axle housing that receives torque in any way. why? once that axle starts to wrap (even as you're trying to counter act it with the bars) it'll put a stress on that weld, and eventually peel the housing open, causing an oil leak. then go ahead and try to weld it shut with oil seeping out. if you use an anti-wrap bracket (http://www.diy4x.com/images/antiwrap%20bracket.JPG) make sure it's welded around the entire plate, and the radius of the bracket gets as close to 1/2 the diameter as possible. mine peeled open for that very reason. or lack there of.
2. heim joints. stay away from them. they're inexpensive compared to a super pivot(Super Pivot Bar End | suicidedoors.com) but you can re-build, service and grease the super pivot. the super pivot won't loosen up like the heims will over time. this isn't so bad with traction bars, you'll notice it more with a 4 link system.
3. Grade 8's. use them everywhere. you'll pay a little more up front, but you'll be thankfull when you don't have to crawl under the truck on the highway at 3am replacing broken suspension nuts and bolts ( that always seem to wander into the tall grass median where you can't find them)
check www.suicidedoors.com for parts, they're pretty good. most of it is for lowered trucks, but some of the parts do an excellent job (super pivots, weld on studs, gussets, etc.) also check out DIY4X: Catering to those who enjoy doing it themselves.
Old 11-30-2008, 05:27 PM
im fat and ugly
1. try and stay away from welding a flange to the axle housing that receives torque in any way. why? once that axle starts to wrap (even as you're trying to counter act it with the bars) it'll put a stress on that weld, and eventually peel the housing open, causing an oil leak. then go ahead and try to weld it shut with oil seeping out.
check suicidedoors.com | This ain't no damn corporation.... for parts, they're pretty good. most of it is for lowered trucks, but some of the parts do an excellent job (super pivots, weld on studs, gussets, etc.) also check out DIY4X: Catering to those who enjoy doing it themselves.
thanks for the input,
i designed the just going off of this || Farmboy Fabrications - The Suspension Specialists || (the misc. area)
from farmboys fabrication
the points you raise are valid, but the only one that conserns me (in my case) is the welding on the rear end. i used grade 8 bolts, and the heim joints i used are solid
i think for my driving style my simple setup is good, i only drive on the road and occasionaly drag race no offroading or extrreme use
