can you change the bulb in the headlight? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-03-2008, 03:38 PM Thread Starter
97powerstroker's Avatar
Quoted: 14 Post(s)
do you have to change the whole headlight or is there a bulb you can change instead?
2002 F-250 7.3 auto CC/SB lariat 116k miles, 6.0 trans cooler the rest is stock.
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #2 of 4 Old 11-03-2008, 03:48 PM
ricksstang's Avatar
Headlight bulb
You change just the bulb. Part # 9007.
You access it from behind. You will probaly have to remove the battery on the affected side to access it.
Rick
Dirty South Strokers
95 Crew Cab Dually PSD
3"dp into 4"exhaust
Gauges: Boost, Trans Temp, EGT
K&N Intake
Performance built Trans
Edge EZ
ricksstang is offline
post #3 of 4 Old 11-04-2008, 07:45 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
It would be a great time to install a Hella harness with their 80/100w 4k Kelvin bulbs!
Cary
CT Performance, Inc. is offline
post #4 of 4 Old 11-04-2008, 08:12 AM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
Go behind the assembly, battery might be in the way and turn and pull. Try not to touch the glassy part of the new bulb when putting in back in.
And if the old one is still good throw it in the glove box so you have a spare
Class of Aug 17, CFD
lifewitlooie is offline
