windshield leak - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-15-2014, 04:47 AM Thread Starter
Scooter11's Avatar
Quoted: 2 Post(s)
windshield leak
I have a winshield leak on my 97 f350. I had the rust fixed on top of the windshield once but it is now coming back. do they make inserts that I can put in the top of the windshield to cut the rust out or do i have to find another donor truck to cut the same pieces from.
Scooter11 is offline
post #2 of 8 Old 02-15-2014, 04:57 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i thought that mine was leaking at the windshield, however it leaked along the rain gutters (can't remember what they are called maybe drip rails) after filling them with silicone the leak stopped. as for your question i don't know
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 8 Old 02-18-2014, 01:10 AM
sputnik801's Avatar
Quoted: 3 Post(s)
Unknown about any body panels for that.... however, my '97 was leaking and rusted above the windshield on the drivers side. I chemical cleaned the rust and wire-wheeled it. Came up with a few small holes. Painted it with POR-15 paint, overlaid fiberglass mesh and put another coat of PRO-15 on. Hardened like steel. I used their etching primer and top coated it with their 2 part gloss black. It worked great and I am now in my 3rd year of this repair. Only downfall is a 2 inch strip of black paint on the roof from the windshield molding back....that pretty much goes unseen.
sputnik801 is offline
post #4 of 8 Old 02-18-2014, 04:35 AM Thread Starter
Scooter11's Avatar
Quoted: 2 Post(s)
What kind of chemical clean did you use on the rust
post #5 of 8 Old 02-18-2014, 03:47 PM
sputnik801's Avatar
Quoted: 3 Post(s)
I used a weak solution of muriatic acid. WEAR GOGGLES & GLOVES. However you can use Oxalic acid, which is sometimes called WOOD BLEACH. It's a powder that you can mix thickly into a paste, which will stay put on the rusty area. Let it sit for a few hours and wash off thoroughly I also used another POR-15 product, metal ready. It's a liquid that leaves a zinc coating that makes paint adhesion better. You can go on POR-15.com and check out their products too. Not cheap, but you get what you pay for.... GOOD LUCK!
post #6 of 8 Old 02-18-2014, 04:53 PM Thread Starter
Scooter11's Avatar
Quoted: 2 Post(s)
Thanks for the info. I will prolly try the the POR 15 first and hope that works.
post #7 of 8 Old 02-18-2014, 08:56 PM
sputnik801's Avatar
Quoted: 3 Post(s)
Good luck. It's amazing stuff. Gloves with that paint too. If it dries, it won't come off of your skin for days!
post #8 of 8 Old 02-20-2014, 03:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
My f250 had a leak there, poured rite on the steering column too, so cal truck with zero rust, I think it needed a windshield gasket tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
