| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
cab lights
Okay I am goin for a classic look ordered a set of obs cab lights from lmc truck factory reproduction not smoked or clear I lookin for the measurements has anydone this I know some of you have I just need the measurements thanx fellas
Are you looking for the measurements for how to space the cab lights on the roof? If so I installed the cab lights on mine and I can go get the measurements for you
you bet ya thats what I'm looking for also is it a fairly easy install?
Ok Ill got take the measurements, yeah they aren't hard to install I just used tape to mark off where they go in terms of the measurements then drilled the holes pulled down the headliner and wired them up
do the obs trucks have them evenly spaced or the middle tree are closer together and the two outside ones are farther? like the new style trucks?
They are evenly spaced mine arent the OEM they are the teardrops but they are very close and I evenly spaced mine, I think it looks better
Ok just went and got the measurements in front where it comes from the slope of the window to the roof I went two inches from that for each light
From the side all the way to the rain collector over the door I went six inches in In between each light I did 9 inches and it spaced out perfectly Now the OEM lights are a little wider so you might have to modify the spacing in between each light Hope this helps |
imma put mine on tomorrow. I bought some recon lights from stealth
