Problem with LMC clear led cab marker lights - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-14-2013, 08:31 AM Thread Starter
natedawg37's Avatar
I was wondering if anybody else has the same problem with LMC clear led cab marker lights. I have bought four sets for my two trucks over the course of just a few years; the led cab lights always seem to be burnt out or only half of it appears to be working inside a signal cab light. Is there any way to fix this, because I would like for them to work, so I don't have to go back to the amber cab lights.
natedawg37 is offline
post #2 of 7 Old 12-17-2013, 02:42 PM Thread Starter
natedawg37's Avatar
I should have mentioned they burnt out because they got moisture inside of them. I was wondering if clear silicone is okay to use to prevent the moisture from getting in?
post #3 of 7 Old 12-17-2013, 05:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've heard of swapping the base and using silicone to seal it (swapping base with stock ones)
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
natedawg37 (12-17-2013)
post #4 of 7 Old 12-17-2013, 06:17 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Personally I would use the clear LMC lens on a factory base then you can use a REGULAR LED that will PLUG in. Not that abortion LMC gives you that you have to cut and splice
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 7 Old 12-17-2013, 08:25 PM Thread Starter
natedawg37's Avatar
I will try swapping the bases.
post #6 of 7 Old 12-23-2013, 10:17 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
The LED board in the LMC lights are crap. I ripped out the LED board from the back side by chopping it up with a dremel. I installed new LED boards from clearance lights.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #7 of 7 Old 10-21-2014, 07:08 PM Thread Starter
natedawg37's Avatar
I ended up getting the clear cab lights from cptrucks.com
