lookin to lift - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-10-2013, 07:15 PM Thread Starter
lookin to lift
got a 96 F250 2wd. lokin to get a lift but not sure how high and make. if possible could ya'll post pics of your lifted obs's and info about the lift please. Thanks in advance
96-Rollin-Red is offline
post #2 of 7 Old 12-10-2013, 08:15 PM
Joe0816's Avatar
What do you use the truck for? Is it a daily driver, tow rig or what?
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #3 of 7 Old 12-10-2013, 08:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Honestly nobody makes parts to lift a 2wd obs diesel, but the 4x4 f150 and bronco parts work on our 2wd although not rated for the weight of our trucks, I've seen them brake, but a few gussets and they were a bit stronger and seem to be holding up for a buddy of mine currently
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 12-11-2013, 08:49 AM Thread Starter
Its a daily driver but it gets used for everything. It gets a work out every 2 weeks or so by moving cattle around to different pastures. and going to work is kinda rough and soupy so im lookin to put bigger more aggresive tires. thats the main cause for the lift
post #5 of 7 Old 12-11-2013, 12:11 PM
Shaun (yota)'s Avatar
Different year 3" body lift and 2" spacers under the lower coil mount. I think the spacer was for a f150.
Shaun (yota) is offline
post #6 of 7 Old 12-11-2013, 12:14 PM
I forgot tire size is 35"
post #7 of 7 Old 12-11-2013, 01:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They don't make a body lift for the Powerstroke because of the core support and the weight of the diesel, also the radiator is different
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
