need d60 help!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-01-2013, 03:38 PM Thread Starter
I have a 97 f250 and I'm doing the Dana 60 swap but not sure what all I need. I was also planing on putting a 4 inch rough country lift on. The dana 60 is coming out of a 95 i think or a 96 and i can get anything i need off the truck. As for the lift would i wanna order an f350 lift then because i don't have the Ibeam front end. Any help would be great
njf5020 is offline
post #2 of 4 Old 12-01-2013, 03:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your gonna need either an adjustable trac bar or drop trac bar mount, and if it's a 95 axle you will need to make sure what kind of calipers it has (slide or bolt style) because you may need rotors, calipers, and brake line "fabbibing" if it's the slide pin style
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 12-01-2013, 03:49 PM Thread Starter
sweet thanks so you think i should order the f350 lift then
njf5020 is offline
post #4 of 4 Old 12-01-2013, 03:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They will honestly send you the drop brackets for an f250 anyway, but yea
And I would unbolt the springs from the truck, the brake lines from the calipers, and the trac bar mount from the truck under the engine, then the sway bar from the axle and the drive shaft, axle should roll rite out, be sure the keep the steering linkage and pitman arm as they are totally different then that of a ttb
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
