OBS Alcoa rim question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-11-2013, 11:42 AM Thread Starter
I'm just picked up a set of rims. They're in pretty good shape but the clear is starting to peal. I'm gonna strip them, polish and I don't know what next.
Has anyone had them powder coated clear??
What are some it her products you had used and had great actual results yourself.
Thanks!
Derailed is offline
post #2 of 6 Old 11-16-2013, 08:59 AM
alpinhi's Avatar
My wheels have the same issue. I am thinking about just getting some of that wheel paint from the auto parts store. I am trying to decide between graphite and flat back. I know there is wheel shop here locally that will refurbish your wheel back to the factory finish. You might check around your area and see if there are any shops that can do it.
Travis
96 F250 Crewcab shortbed 4x4
Tymar intake, Warn hubs, B&W Gooseneck and fifth wheel hitch, 285/75/16 Michelin A/T2's
09 Unlimited Jeep Rubicon
2" lift, 315/70/17 BFG At's, Warn 9000lb winch.
Trying to afford modifying 2 vehicles is tough!
IAFF Local 1596
alpinhi is offline
post #3 of 6 Old 11-17-2013, 02:55 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The last i heard, anything being powder coated needed to be sandblasted(for proper adhesion). I wouldn't sandblast aluminum wheels
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 6 Old 12-01-2013, 09:15 AM
97dieselstroke's Avatar
I agree with brad you dont want to sand blast your wheels it will leave a very grainy texture to them you could try getting them soda blasted that would work for powdercoating or just acid wash them an polish them after that. get a good automotive clear and spray them. they will look great. but it might almost be worth it price wise to have it done professionally. i know a shop around here does 22.5 s for semis for cheap.
97 f350 cclb 4wd xlt 7.3 e4od 34x12.5 Bfg allterrains 3" diamondeye s/s downpipe to 4" to 5" dual black turnout stacks, aux trans cooler, trans temp guage,diy 6637 intake, ts 6 pos chip. fpr shim, tc lockup switch, 10k mod
95F350 CCLB xlt 7.3 zf5 4wd 4" lift 35" procomp extreme all terrains 3" diamond eyes dp 4" straight ex. diy 6637
97 f250 eclb xlt 7.3 e4od 4wd bone stock
97dieselstroke is offline
post #5 of 6 Old 12-02-2013, 05:34 AM
Quoted: 4 Post(s)
I would go to your powdercoater and see what they say
post #6 of 6 Old 12-02-2013, 09:51 AM Thread Starter
Powder coat guy seems to think it will work. He said he's done them before with good luck
Derailed is offline
