Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Exterior Discussion
Old 07-10-2008, 12:14 PM
GM Duraturd GM Duraturd is offline
Send a message via AIM to GM Duraturd
Tire Sizes
Whats the biggest tire you can put on a stock height 95 F-250 with none or little rub?
Old 07-10-2008, 12:20 PM
george.ratliff george.ratliff is offline
i want to know the same
Old 07-10-2008, 12:34 PM
welder24 welder24 is offline
I have 285 75 -16 on a F350 crew cab but I added a leaf to the front spring. Not sure if they would rub on stock truck.
Old 07-10-2008, 12:47 PM
bucwheat bucwheat is offline
My 350 has coil springs,I would like to run 285's also.mine is a dually so I think a spacer on the rear is required.
Old 07-10-2008, 01:42 PM
Smooth Criminal Smooth Criminal is offline
I know you can fit 285's with ease, you might be able to fit 305's. I think it all depends on how much your front springs sag. I have 265 on my 96 250 right know but I'll probably go with 285's or 305's after I get the add a leafs or I might just swap in a D 60.
Old 07-10-2008, 05:27 PM
yeah I have 265's now and they are just to small and very narrow (265/75r16) I will run them till they are shot tho, I was just curious for the future
Old 07-10-2008, 05:33 PM
PSD0389 PSD0389 is offline
<--- OOPS, now fixing
Send a message via AIM to PSD0389
Without any trimming or anything the biggest will be a 285/75/16 thats what I used to have and any wider or taller of a tire I would have had to do some trimming. With my 2.5" lift though I fit 315/75/16
Old 07-10-2008, 05:56 PM
donald lorbeske donald lorbeske is offline
I had a F250 97 ADDED A SPRING IN FRONT PUT A ONE AND HALF INCH SPACER ON THE BUMPER FIT 305 AT NO RUB
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
