Air compressor install - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-06-2013, 08:11 AM Thread Starter
Gaius's Avatar
Quoted: 40 Post(s)
I've had a Viair compressor and tank lying around for a few years, decided to put it on the truck to have air on the tow rig also.
Where are you guys installing it? I'm thinking of making a bracket for it to sit on under the truck, but a little worried about gunking it up.
Thoughts?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #2 of 12 Old 09-06-2013, 04:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Frame mount with skid plates and access hatch ftw
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 09-06-2013, 04:42 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
i have a 5 gallon bolted to the bed in the corner , the compressor is mounted to the frame and air hose through the bed into the tank
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 12 Old 09-07-2013, 02:32 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I have mine mounted behind my rear seat on a custom bracket. For as little as it runs, I can deal with the little noise and it is out of the elements
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 12 Old 09-09-2013, 03:04 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
^^^ and usually when its running your outside using it
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 12 Old 09-09-2013, 05:47 PM
Snake's Avatar
Quoted: 46 Post(s)
Thoughts?
Is your spare tire still under the bed?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 12 Old 09-10-2013, 02:57 AM
Quoted: 4 Post(s)
Actually, I am inside dialing in the ride with the remote control
post #8 of 12 Old 04-19-2015, 09:11 PM
Tdubyawilson's Avatar
I just put there continuous duty pump kit on this weekend,the kit will air up a 37" tire ,I got an after market gauge for running my airbags it has 2 needles in 1 gauge also has 2 switches for airing up the bags individually I highly recommend that kit
Tdubyawilson is offline
post #9 of 12 Old 04-19-2015, 09:30 PM
PowerStrokedRedneck's Avatar
What kit did you get?
PowerStrokedRedneck is offline
post #10 of 12 Old 04-20-2015, 06:47 PM
This kit from viair
ID:	415066   Click image for larger version
ID:	415074   Click image for larger version
