Cracked radiator support? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-01-2013, 04:43 PM Thread Starter
97Strokin''s Avatar
Hey guys so the radiator support in my 97 obs keeps cracking in the same spot. And ideas what would cause this to happen?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 7 Old 09-01-2013, 06:52 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
It is completely "normal" for the top bar to get stress cracks.
I weld the cracks, then gusset them. Never anymore problems
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 7 Old 09-01-2013, 07:47 PM Thread Starter
97Strokin''s Avatar
Thinking about putting an angle iron on the front would it help?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 7 Old 09-01-2013, 08:37 PM
Quoted: 4 Post(s)
Yup. I just use 18ga sheet metal as a gusset
post #5 of 7 Old 09-08-2013, 04:30 PM
Mine also broke on two different spots on the top bar.
I used a 16ga angle, as wide as the rad support welded on the top and on the front. Topped it with a 46" 1/8" thick flat bar also welded across. Should be strong now.
1996 Ford F-350
7.3 Powerstroke, manual 5 speeds, 4x4, Crew Cab, Long Bed, Srw, 4.10 gears.
1995 Ford Taurus SHO
V6 3.0L DOHC Yamaha, manual 5 speeds, Eibach springs, Koni struts, Quaife ATB diff, Brembo brakes, K&N filter, solid motor mount, 2x Pionner PIAA 10" subs + JBL GTO 301.1II amp, Cobra CB radio and wilson antenna
crazy_canadian is offline
post #6 of 7 Old 04-19-2015, 09:13 PM
Tdubyawilson's Avatar
Does anyone know of an aftermarket replacement for the core support for the 7.3? Or is my only option fixing the one I have?
Tdubyawilson is offline
post #7 of 7 Old 04-21-2015, 02:28 AM
Quoted: 4 Post(s)
Fixing is your ONLY option. OR finding good used one. Look in the classifies HINT HINT
