How dually spare tire mounts under bed with dual tanks - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-08-2013, 10:10 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys when i got my dually it had a spare tire and rim but it was just floating around in the bed and from what i have read is they actually did mount under the bed even with the dual tanks. Is this true? is so i cant tell how it does, it obviously doesnt have the same winch crank system the SDs have. Anybody got a picture of what it should look like?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 3 Old 08-08-2013, 11:26 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
The duallies had the same spare tire carrier as the other OBS trucks (and never had the "crank-down" carriers like the SD's had). They basically had two "clip-nuts" that clipped over the holes in the frame (to provide threads) for the long bolts that held the carrier bar in place. The carrier bar also had some parts to hold the tire on the bar. Here's a decent diagram of it: 1995 FORD F-350 Parts - AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
Cheers!
Patrick Feeley is offline
post #3 of 3 Old 08-08-2013, 11:37 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Cheers!
Hmm i noticed when i was down there i saw the two poles down there and i assumed it had something to do with it but i couldnt figure out how, ill have to look to see if i have the other pieces too
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
