Best brakes for OBS dually - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-18-2013, 09:48 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys i need brakes for my newly acquired OBS dually 2wd. What do you all run for the front pads and what rear shoes do you run? Not looking for the best most expensive ones, just some good ones that wont need replacing after a year. Also if you could point me to a diagram or write up how to do brake drums shoes because i have never had the...pleasure...to do them.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 18 Old 06-18-2013, 09:52 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
MOTORCRAFT!!!!!!!!!!!!!!!!!
2000-7.3L is offline
post #3 of 18 Old 06-18-2013, 10:17 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Some things you only use motorcraft for and brakes are not something that i would used them for. Filters yes, fluids no, gaskets yes, brakes no
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 18 Old 06-18-2013, 10:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Hawk pads I hear are great, as far as doing drums, pull the "drum" off, look at it before you remove anything else, set your new pads in front of you and put it all back exactly how you took it off
I have napa pads on mine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 18 Old 06-18-2013, 10:24 AM
2000-7.3L's Avatar
uhhhh Motorcraft oil and trans fluid i would say Motorcraft. Thats all I runn in my 7.3L. Pat how many miles on the 2WD you got there?
post #6 of 18 Old 06-18-2013, 10:48 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
So its not a huge deal if i got some cheap napa pads and shoes it mostly just a DD if i tow its with my SD.
Yea but the way i see things other companies like shell(rotella t5/6), mobile 1, castrol, pensoil, etc have done wayyyy more testing on their oil than ford engineers ever have so i tend to trust them more than ford who just buys it from whoever is cheapest that meets requirements(someone correct me if i am wrong)
As for miles the cluster says 227777ish but the PO said that the PO before him replaced the cluster and its closer to 190000. Who all is telling the truth is up for debate without paperwork but id believe it based on how well its taken care of.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 18 Old 06-18-2013, 10:52 AM
2000-7.3L's Avatar
well let me say this, there are guys on here saying that they have owned there trucks since new, or like new that now have 100,000 miles on them. They make a thread stating that the brakes have never been done and they want to upgrade there brakes. Hmmmm let see, a set of pads that lasted over 50,xxx miles, i think thats pretty damn good in my book. So why upgrade? the pads laster over 50-75,xxx miles, why would you want to upgrade? If you think about it, how long would it take you to drive that truck 50-75,xxx miles?
RANT OVER, hope this helps! Just giving insight on the whole "I want better brake pads"?!
post #8 of 18 Old 06-18-2013, 10:54 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I would say motorcraft fluids, pads, and parts are great IMHO, they were specifically designed for that exact application, and not "copied" to sell cheaper, that being said I have ford do all my oil changes in my f250, and I run valvoline in my f350, both over 300k, both dd and do as much towing as I can find for them, brakes I just don't get the cheapest, but I won't pay overkill prices for a product because of the name written on them
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 18 Old 06-18-2013, 10:56 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Your logic is sound, but..... Upgrades can be more efficient as to warp less, wear smoother and stop shorter, I'm a big fan of ford parts tho, incomming pm btw
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 18 Old 06-18-2013, 10:59 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yea i have no problem with motorcraft parts they obviously work good, but like you said i dont want to pay for the name if theres a better product out there thats cheaper
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
