97' F250 - weird brake light problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-15-2013, 04:43 AM Thread Starter
I have a 97' F250 Power Stroke with a strange problem.
The brake lights won't go off.
I had a new steering column put in at the local auto repair shop. Everything was fine when I picked it up, then when I got it home I noticed that the brake lights remained on after I parked the truck.
Key on, key off, push brake, let off brake, emergency brake on, emergency brake off - nothing seems to matter. I finally disconnected both batteries which of course turned off the lights but reconnecting the batteries turned them back on.
The steering column they used was from a vehicle with an airbag & my original did not have an airbag but they made it work. Could this be an issue?
The repair shop is closed until Monday AM.
Where do I look?
W8EJO is offline
post #2 of 6 Old 06-19-2013, 05:01 AM Thread Starter
This gets stranger and stranger.
If I start the truck, the brake lights go off when they should and on when they should.
When I shut it off and the truck sits for 8-10 hours (e.g., overnight) the brake lights will come back on by themselves as if a little elf is in there pushing on the brake. I re-start the truck & they go off. The cycle repeats the next morning when I wake up & look out the window to see the brake lights have mysteriously come back on overnight - again.
What could be causing this?
W8EJO is offline
post #3 of 6 Old 06-19-2013, 05:42 AM
jake-96-7.3's Avatar
Send a message via Yahoo to jake-96-7.3
Brake light switcha are sometimes adjustable not sure if they are on these trucks never looked at mine but the reason there going back on sometime later is because the brake booster is slowly losing vacuum as the truck sits completey normal with the truck off keep pressing the pedal notice How it gets harder same thing it just takes longer if u don't push it ... so its moving out every so slightly and bam lights are back on I'd be taking it back to that shop have them Figure it out
1996 F250 ext cab long bed
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
Dacco billet cover triple clutch HD Torque converter
3in down pipe
5in straight pipe
6 in tip,
true cool 40,000btu trans cooler
203 thermostat
Firestone ride rite air bags in rear
tinted head lights turn signals markers sd tinted fogs
Kenwood head unit
full JL audio sound
jake-96-7.3 is offline
post #4 of 6 Old 06-19-2013, 05:47 AM
The switch is mounted at the top of the lever that the pedal is attached to so they could of bumped it when they were changing the column
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
3in down pipe
5in straight pipe
6 in tip,
203 thermostat
Kenwood head unit
full JL audio sound
post #5 of 6 Old 06-19-2013, 06:12 AM Thread Starter
Thanks Jake.
So if i understand you correctly, it's normal for the brake booster to slowly lose vacuum as the truck sits. As this happens, the brake pedal slowly moves down, maybe by fractions of an inch, as if someone is pushing it slightly.
And if the brake light switch isn't installed or adjusted properly the brake lights will come on due to this slow, normal loss of vacuum in the brake booster.
Do I understand this?
W8EJO is offline
post #6 of 6 Old 06-19-2013, 03:22 PM
you are correct so if they bumped it or bent it somehow when installing the column that could cause your issue
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
3in down pipe
5in straight pipe
6 in tip,
203 thermostat
Kenwood head unit
full JL audio sound
