Adding keypad entry to an OBS F350 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-05-2013, 05:23 PM Thread Starter
nohsp4u's Avatar
Ok,
I have heard rumor that installing a keypad for keyless entry to an OBS is possible provided you have keyless remote entry.
Anyone done this and/or what you share how to do it? I would think i simply need to connect the keypad wires to the module but that is where my guessing ends.
I want to do this after vacation so if you want to share, i want to learn.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 9 Old 06-05-2013, 06:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If you search adding rke to an obs the write up is in there, just pin in 7 wires and your done, but have to have rke in the truck already
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 06-18-2013, 09:45 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Is testing if you have RKE in the OBS just like in the super duty Key ON/Key OFF like 5-7 times?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 9 Old 06-18-2013, 10:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
No, look under the dash it's between the chime box and cubby hole to lower right of steering wheel, has 3 plugs in it, if you remove the lower dash its easy to spot, has 5 digit code on it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 9 Old 06-18-2013, 10:36 AM
Chapter Director
Quoted: 5 Post(s)
Sweet thanks ill take a look tonight. If i have it can i just buy one of those cheap fobs and program it or whats the procedure?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 9 Old 06-18-2013, 10:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
There is a grey 2 prong plug you have to "short" it and then program the key fob, not sure on the exact procedure but it's in the rke write up in the general chat, bill did a good one on programming the fob and adding the key pad
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 06-18-2013, 10:50 AM
Chapter Director
Quoted: 5 Post(s)
That sounds kinda janky but ill take a look at the sticky thanks.
I see what you meant the other day by OBS guys just derail, i have only had mine for less than a week and im already doing it:hehe
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 9 Old 06-18-2013, 11:01 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yessir, and the dealer has a plug they hook in there that does exact same thing without looking ghetto lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 06-23-2013, 06:34 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
Originally Posted by nohsp4u View Post
Ok,
look here! I have it saved in my "to do" list
OBS keyless entry (RKE) retrofit.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
