OBS Topper / Cap - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-03-2013, 01:34 AM Thread Starter
OBS Topper / Cap
I need to put a topper on my truck for vacation and am checking out craisgslist.
Are there any other brands, years or models of trucks that have a comparable topper that will fit? It doesn't have to be perfect but close!!
97 f350 CC LB
Thanks for your help!
sparkey75 is offline
post #2 of 11 Old 06-03-2013, 08:14 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Any 8 foot one should work, the tonneau covers are the tricky ones iirc
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 06-04-2013, 04:36 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
96 and older F150
97 and older F250HD/F350
93 older dodge
87 and older chevy
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 11 Old 08-06-2013, 03:13 PM
alpinhi's Avatar
I am trying to find a Shell for my CC SB and am having a hard time also. Will a shell from trucks mentioned above fit as long as they are for a short bed?
Travis
96 F250 Crewcab shortbed 4x4
Tymar intake, Warn hubs, B&W Gooseneck and fifth wheel hitch, 285/75/16 Michelin A/T2's
09 Unlimited Jeep Rubicon
2" lift, 315/70/17 BFG At's, Warn 9000lb winch.
Trying to afford modifying 2 vehicles is tough!
IAFF Local 1596
alpinhi is offline
post #5 of 11 Old 08-06-2013, 05:45 PM
early99psd's Avatar
Quoted: 12 Post(s)
The bed size might fit, but the cab angles will be off. If you don't care if they line up then go for it.
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #6 of 11 Old 08-07-2013, 02:44 AM
Quoted: 4 Post(s)
YES, and the cab angles are Not off
post #7 of 11 Old 08-07-2013, 08:07 AM
early99psd's Avatar
Quoted: 12 Post(s)
Your right on the fords, they are the same. But the dodge and the Chevy are not the same as far as a fit on the cab how it should be. If you want a shell that looks right then buy one made for your truck.
post #8 of 11 Old 08-08-2013, 03:08 AM
Quoted: 4 Post(s)
Before the big 3 went in their own direction(88 chev, 94 dodge,99ford) the caps were all the same. They did NOT make one for each brand like they do today.
For example. This came off of a 76 chevy
And this came off a mid 80s dodge
post #9 of 11 Old 08-08-2013, 05:57 AM
early99psd's Avatar
Quoted: 12 Post(s)
I am not sure what brand your talking about, but the centry brand they did in fact make one that was for the ford and one that was for the Chevy. The Chevy cap would fit the older dodge.
post #10 of 11 Old 08-08-2013, 08:56 PM
leojr's Avatar
Quoted: 4 Post(s)
Had to be patient (watched Craigslist for about 6 months) but finally found one the right color and size. I put it on for road trips.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
