Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Exterior Discussion
Old 03-11-2008, 07:37 PM
MNTAIR MNTAIR is offline
95 Headlight removal
Has anyone tried removing those headlights on a '95? There's no info in my Chiltons manual.
I did get the top two clips removed easily, but the bottom clip has me puzzled...I don't want to break it
Old 03-17-2008, 04:20 PM
parrothead96 parrothead96 is offline
pulled mine off to replace them with some clear ones a few weeks back. Take out your batteries, there are nuts directly behind the lenses that need to be taken off. Once the batteries are out you will see the lower nuts ones that you missed as well.
PIA if you ask me. Oh yeah, make sure you pull your truck up to the garage door before you start. Turn on the headlights and mark where they are so when you install the new lights you can align them right. I forgot that part and spent a few nights re-aligning the lights to where they need to be.
Old 08-05-2008, 05:22 PM
demodeke18c demodeke18c is offline
Send a message via Skype™ to demodeke18c
good question, tried to do mine today but was puzzled. I know i have to take off the metal clips but the lowest one is the stumper.
Old 08-20-2008, 06:14 AM
lilgreen lilgreen is offline
When I replaced mine I used a long pair of needle nose pliers to get the bottom clips off. Like parrothead96 said make sure to pull your batteries. This will make installation a lot easier.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
