Bronco doors on an F250? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-19-2013, 12:41 PM Thread Starter
95_Powerstroke's Avatar
Send a message via MSN to 95_Powerstroke
I was at the junk yard last week getting some parts for my truck and I stumbled across a MINT Eddie Bauer Bronco in the same color as my truck. My doors and passenger fender have a lot of damage and all of these panels on the Bronco are perfect. Would the wiring from an EB Bronco work on my XLT though?
(And I know there is a tan bottom piece on the bottom, that section will be bed lined eventually but the main body color is the same.)
Eric
1996 F350 XLT 4x4 E40D
1995 F250 XLT 4x4 E40D- Totaled on 02/06/2017
95_Powerstroke is offline
post #2 of 5 Old 05-19-2013, 01:05 PM
alaskan155's Avatar
Quoted: 65 Post(s)
there the same, all 80-96 f-series/bronco doors are the same minus mirrors and wiring.
i think the wiring breaks for the doors are 80-86, 87-91, and 92-96(which i believe go behind the dash and dosent have plugs in the kick panel like the 91 and lower), so you would just use your trucks wiring in the bronco door
alaskan155 is offline
post #3 of 5 Old 05-19-2013, 01:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
All panels from door forward and wiring will be exact same as your truck aside from the dash harness
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 05-19-2013, 02:09 PM Thread Starter
That's what I needed to know, thanks Kris!
Eric
post #5 of 5 Old 05-19-2013, 02:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
No problem, what year is this EB bronco btw? Pull the ohc, sunvisors, and the mirrors should also be the nemo with signals built in to them, btw the bronco door harness should also have the power mirror harness that you may not currently have
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
