Block Heater Plug Reloaction - Ford Powerstroke Diesel Forum
Old 03-04-2008, 05:17 AM
Well i got the cover for next to nothing and it didnt have a part number on it or id list it up for ya. The plug on the inside i went the the local Do It Best hardware store and picked up a water proof plug for 3.00 and the "massage" it to fit inside the cover, here are some pics of me doing it. Took about 30 minutes. The tools i used were: 13/4" hole saw, 3/16" drill bit, T30 bit, 6MM wrench, wire strippers, a phillips screw driver to tighten the wires.
THE PARTS
Grill before
Old 03-04-2008, 05:18 AM
I can get some pics later on today of it on the truck, looks great and works even better!!
Old 03-04-2008, 05:50 AM
Shaking the Bush Boss
good write up, whats in the lower right corner of your grille?
Old 03-04-2008, 05:51 AM
a plug for jumper cables
Old 03-04-2008, 05:52 AM
Looks great, i have all the parts and need to get mine done too.
Old 03-04-2008, 06:04 AM
did you trim the fiberglass support behind the grill?
Old 03-04-2008, 06:32 PM
no i only had to trim and round off some edges on the plug cover its self
Old 03-04-2008, 08:53 PM
with the grille installed...the cords not bent to a 90*, or smashed? Mine had to be trimmed out alittle, because of it. Where did you get the plug for the jumper cables?
Old 03-04-2008, 09:00 PM
looks great!!!!
Old 03-04-2008, 09:30 PM
SMOKE ROLLER
Looks good...
